engine code?
Can anyone tell me the engine code for a 97 Mirage LS 4 dr? Thanks.
RE: engine code?
97 Mirage 4drs came in 2 trims:
DE - 4g15 1.5L 12 valve SOHC ES - 4g93 1.8L 16 valve SOHC LS's were coupes only, ES's were sedans only up until 2002 I think, then they all switched over to LS for either coupe or sedan. |
RE: engine code?
i dont know if thats right. im pretty sure that my engine code is 4g93 and i have a 4dr ls
RE: engine code?
I might have em switched, I know they did something funky with the trim packages as the 5th generation came to a close. Long and short of it though, if it's not a DE, it's got a 1.8 in it and life is much simpler for you.
RE: engine code?
Production 1997–2002 Assembly Assembly Nagoya plant, Okazaki, Aichi, Japan Normal, Illinois Body style(s) 3-door hatchback 4-door sedan 4-door wagon 2-door coupe Layout FF layout Engine(s) 1.5L 92hp I4 1.8L 113hp I4 http://en.wikipedia.org/wiki/Mitsubishi_Mirage |
