Help with a swap
Ok i started my mitsubishi mirage 1994 that i comes with an 1.5 L and i swap and 4G93 SOHC the one that it have valve cover black, and the throttle body is way different than regulars, i was told that it was an Japanese Edition, any ways... i put and Mitsubishi Galant 2.4L Tranny and car is running pretty strong...
But... i was reading on the internet and stuff,,, that i can make that engine 4G93 SOHC to a 4G43 DOHC and i bought the DOHC head from a Hyundai Elantra from about 1995 or 1996... wish its Mitsubishi also, but now im just trying to read arround to be at least 85% sure about this is going to work (hehehe) so if so... when i go to get the timming belt, wish one should i buy? should i need to make any mods, or it should go right in? and all these tips will be really appreciated... thanks a lot for your time... And i also can post some engine pics... if needed... |
Hey i have a 98 1.5 liter what wud be good to swap in it cheap wise cause i found a turboed 4g63 out of early 90's eclipse u thik that wud work i am new on here?
The head off the older elantra's are the same head as the 4g63 dohc engine.
Problem is will fit on the engine bay
