High and low beams are on at the same time
2000 Mirage DE Coupe 1.5l 5 speed
I just bought this car about a week ago. My problem is that when i turn on the headlights the high and low beams come on. Flicking the dimmer switch doesnt always turn the high beams off. When I try to turn the high beams off the high beam indicator light doesnt go off but it does get a slight bit dimmer. This is an intermittent problem so i dont think it could be a relay issue. I checked all the fuses and cleaned/re-lubed the dimmer switch. Any suggestions? |
you need a new dimmer switch
Thanks for the reply. Since posting this i have replaced the relay and dimmer switch. Neither fixed the problem. I hace no idea what else could cause this.
