Intermittant Check Engine Light Problem
Just bought a 1997 Mirage LS 1.8L. At speed there is a noticeable hesitation and clicking noise from glove box. Doesn't happen all the time and usually it's about four times. The Check Engine Light comes on briefly each time. Any ideas? Thinking it could be a cam sensor, EGR problem or computer is bad. Thanks for any help. It's got 135,000 miles. Everything else seems good except for this problem.
clean your battery cables
Originally Posted by mxmikie
(Post 297051)
Hi,
Try scanning trouble codes with obd scanner. And then check engine code |
Update
(Post 297051)
