TP switch
Replaced a throttle position switch on my dads gf car. After installing and checking the voltages (reference voltage, idle and WOT) that were within ranges as specified in the service manual... the car had a really low idle once it warmed up. It would die out when i drove it down the driveway and came to a stop. Also once the replacement TP switch was intalled the "check engine" light that was illuminated went out. However after sitting for a while and turning the vehicle back on the "check engine" reilluminated. The reason for the TP switch change was due to get a code from the OBDII scanner that referenced the TP switch. 0120
Could there be any other problems to cause a code like that? |
might help if you tell us what you're driving.
this post is in the mirage forum so thats what i would assume it to be. and zx12 did u try to clean the maf with maf cleaner? if that doesnt work, maybe a bad maf sometimes they can be tested at autozone
1 Attachment(s)
Originally Posted by jason clipse
(Post 252423)
the fuel trim bank one issue could be caused by the maf. this is a 4 cycl right so there is only one bank, which means you are either running rich or lean. could be caused by o2 sensor or maf, usually its the o2 sensor. but usually that wont make the car idle wierd or shut off on decel, that sounds more like the maf, like i said i would take it to an autozone and see if they can test it.
(Post 252505)
try cleaning it first, that may be it. or actually when was the last time the air filter was replaced, it could be as simple as that. the air filter is so clogged that it isnt getting any air. then if cleaning it doesnt work and the air filter is good then try getting it tested
