turn signal stays on
Old Jul 23, 2008 | 12:04 PM
y26's Avatar
y26
Default turn signal stays on
Hello,
I hope somone can help me trouble shoot this. Me left turn signal is staying blinking even though the lever is in neutral. When i try to move the lever for the right turn it still stays on lefft. Hazards work fine and everything else on the lever ie lights highbeam works. 97 mirage 1.8.
Thanks
Old Jul 23, 2008 | 05:45 PM
dsm1990gsx's Avatar
Default RE: turn signal stays on
I would say you have a bad multifunction switch,the contacts in the switch are probably worn.
Old Jul 23, 2008 | 05:56 PM
Happens all the time.
Old Jul 24, 2008 | 09:24 PM
y26's Avatar
y26
Thanks so are you thinking i just need to swap the switch??
Old Aug 13, 2008 | 08:27 AM
christyaq's Avatar
I have the same problem with my 2002 Mirage. I just took out the fuse. It's been like a month and still can't find a switch. If you find one let me know where please. Thanks!
Old Aug 13, 2008 | 06:23 PM
dsm1990gsx's Avatar
ORIGINAL: christyaq
So how do u drive w/o turn signals?
Old Aug 18, 2008 | 09:24 AM
andry's Avatar
ORIGINAL: y26
yes if the switch broke, you have to replace it.
Old Aug 24, 2008 | 03:13 PM
christyaq's Avatar
ORIGINAL: dsm1990gsx
The old fashioned way! besides, here in New Mexico the law on turn signals is "turn signals need to be used only when it affects other traffic" so I just hope I don't get pulled over when traffic is busy!
Old Aug 24, 2008 | 03:29 PM
christyaq's Avatar
Stupid question- How do you know if it's broken? I mean, my switch still goes in the up, mid, down postion. it's just the signal stays on no matter what position its in. Ok, maybe this is how you know its broken, right! told you-stupid question!
Old Aug 24, 2008 | 07:02 PM
dsm1990gsx's Avatar
ORIGINAL: christyaq
If you pull the switch out you can ohm the different positions and see if there is any continuity. If there isnt any continuity then the switch isnt making contact and its bad.
