What swap for a mirage
Old Jul 4, 2007 | 01:10 AM
juan2k2001's Avatar
Default What swap for a mirage
I dont know **** about mitsubishi..Im a honda fan actually but I got my dad mirage cuz its ****ed up but I wanna make boost or do a swap but dont know what to put in there..Im just doing it for the hell of it..Like can I put an eclipse motor or some**** help..Or what do you need to do to do a swap...It's a 96 or 97
2 door mirage..
Old Jul 4, 2007 | 01:38 AM
davidmitsusrock's Avatar
Default RE: What swap for a mirage
you can do a 4g63 swap on these cars....
Old Jul 4, 2007 | 12:28 PM
juan2k2001's Avatar
what motor is that from and what would I have to do to put it in...special motor mounts.wire harness what?
Old Jul 4, 2007 | 02:35 PM
Dusty Eclipse's Avatar
What motor is that from?? Are you kidding? I thought even the Honda boys knew this one... Its from an Eclipse. A 1/2G eclipse.
Old Jul 5, 2007 | 12:30 AM
and a evo, and a galant vr-4
Old Jul 7, 2007 | 08:29 PM
juan2k2001's Avatar
what do I have to do..Is a mission to put it on..or where do I get special mounts..what do I have to do..
Old Jul 8, 2007 | 12:49 AM
Lil Evo's Avatar
the year will pretty much dicate what swaps you can do and how easily. if you've got a 96 Mirage, you've got it made. The 4g63t out of the 1g (maybe 2g, don't know for sure) eclipse or the Evo I-III will drop straight in. If it's a 97, you've got your work cut out for you. 97+ (5th generation) USDM mirages have a different chasis than their Japanese counterparts (8th gen Lancer I believe it is), so your options for swaps are much narrower. Obviously, if you've got the 4g15, you can swap in a 4g93 and call it a day, drop in a 4g64 out of the 00-05 Eclipse (and get the 98 Eclipse Spyder ECU & harness).........there's a v6 that'll fit, but the cost and headaches really aren't worth the power gain unless you can find the 3kgt-TT motor, but be prepared for your nose to drag. Then there's the wonderful 4g63t, every 5ger's dream. Unfortunetly, you'll need to import an Evo IV-VI.5 motor (and mess with getting the wiring harnesses straightened out), or pull one out of an Evo VIII. Either way, expect to pay at least 10k.
And I'm kinda disturbed that the Honda crowd doesn't know what a 4g63 is.......what'd they think was dusting them all these years?
Old Jul 29, 2007 | 02:51 PM
Tindias's Avatar
I have a similar question. I have a 91 Mir I got from my sister, it needs some work but has been reliable for a long time. I would like to know what motor can be swapped in easily? I am looking for something that I can boost and install with little modification to mounts.
Old Jul 29, 2007 | 05:30 PM
direct's Avatar
ORIGINAL: juan2k2001
Old Jul 29, 2007 | 09:58 PM
Lil Evo's Avatar
91......that's a 2nd gen mirage if I'm thinking straight......in which case you can drop in a 4g63t, or (again, if I'm thinking clearly) a 4g61t, which was the factory turbo option for that particular generation. If you can get your hands on the motor, tranny, computers, diffs and drive train of a 4g63t, you will have an absolute rocket.
