Wiring Tachometer 4g15 / 1.5 injection 1992
Hello !
I realy need help with tachometer wiring, Actually only with Signal wire. Where should i connect that Green (signal) wire from Tachometer ( aftermarket ) Cause in my car does not have coil where to connect it. So do i need to find some wire from ECU or what :confused: ALL HELP WELCOME ! And thank you ! =) |
I put a new cluster with tachometer in my 00 Mirage, but i'm not sure about yours. On mine there was a little blue connector in the engine bay on the passenger side where the wiring came out the cabin. That is the tach signal. But i actually bypassed it and tapped into the wire on the ECU. Although i know its different on yours.
How about trace the tach signal wire from the original tachometer.
