01 Mitsubishi Montero 3.5 V6,Timing belt problems,Truck has 160,000 for sale for part
01 Mistubishi Montero,3.5 V6,160,000 miles,ran fine everything works,sitting in front of Apt other day with truck running,just quit,turned over but never restarted,took to shop Monday,they said timing belt was hitting teeth and that I had a interference motor and that I would need to purchase a timing belt kit,6hrs of labor for $1000.00 and then they could tell me if motor is bad,called Mitsu dealer he said don't spend the 1000.00 because the motor is gone.Doe anyone know if this is so? If so is there anyone who needs a excellent white truck with bad motor,contact me
Yes, the montero has an interference engine so timing belt changes must be done at recommended intervals. Once it breaks then engine is useless. I wouldn’t spend $1k on parts and later on finding out my engine is no good. |
Originally Posted by carlsson01
(Post 326030)
Hi HunterD....forgive my wrong choice of words....I should have said the he’s gonna spend a lot to fix the engine if the timing belt breaks while engine is running. Just emphasizing the importance of changing timing belts on time. He was already quoted $1,000.00 just to replace the timing belt....I think I paid $500 labor when I had mine done...one of the first things I had done when I got my Montero 3 years ago. I would agree with HunterD to have a camera down the plug holes and see if any valves are bent before having the timing belt done and finding out later that it won’t run right. |
(Post 326056)
No worries HunterD:). i wonder what AnthonyAlex did to his montero..if you ask me...$1k for parts and labor for a timing belt change is on the high side. |
1k is high. Unfortunately that's what Mitsubishi dealer charges for it on Montero. I remember the pain of it when we had to pay that much for the job years ago. At that time the timing belt was the "mystery box" that you don't dare touch yourself :( I'm glad I got past that fear and learned to do it myself.
I totally agree with Hunter D. The prior owner of my 94 Montero had replaced the timing belts incorrectly, then started the car, and "oooooooops".....ker-clunk!. Immediately bent the valves on one side of the engine. I guess that owner got the same advice, and chose to get rid of the poor Montero. It has been repaired, and the engine runs like a new one.
