-   Mitsubishi Montero & Montero Sport (https://mitsubishiforum.com/forum/mitsubishi-montero-montero-sport-14/)
-   -   '01 montero limited making LOUD clicking/knocking (https://mitsubishiforum.com/forum/mitsubishi-montero-montero-sport-14/01-montero-limited-making-loud-clicking-knocking-49921/)
Blanevspredator Jul 16, 2016 05:00 PM
I was just gifted this montero and I am attempting to fix it to use as a family vehicle. The noise changes with the Rpms however is most noticeable in idle.
I was hoping someone out there has had this problem before and can tell me what it is so I can start to get my head wrapped around this thing. My gut is telling me timing belt but I've heard rocker arm from a mechanic and another mechanic at Mitsubishi told me that I needed a new motor... I refused to buy that load of b.s. And now I'm here.
Thanks
HunterD Jul 16, 2016 06:43 PM
Check your timing belt tensioner.
Caneisable Feb 13, 2017 11:44 AM
Noise
Mitsubishi montero 2001 engine noise - YouTube
Thanks
did you ever find the cause of the noise I have the same much appreciated
Littlehammer Feb 16, 2017 02:55 PM
I'm not a Mitsubishi Tech or anything. But I've owned a 2000 Montero Sport for 15 years now .it has 203k. It's been doing the loud clicking thing for about 6 months now. Luckily I have a friend that is a a Subaru mechanic working in the same shop as Mitsubishi. I was fortunate enough to get a hold of the mechanics shop manual and it explains the noise as being faulty lash adjusters on the valves, to which my mechanic friend agrees. I've never taken any of my vehicles to a shop to be worked on so I'll be taking her apart again .I'll know for sure if that is the problem in couple of weeks. As you may or may not know the intake plenum and intake manifold have to be removed so while they're off it's wise to put new spark plugs and timing belt or else they'll be coming off again soon. I'll let you know whether I was right or wrong. By the way a can of STP works for a day if you want to enjoy quiet for one day.
HunterD Feb 17, 2017 12:32 AM
Valve lash adjuster noise is very different from the noise in this video. Have you tried to do a valve lash adjuster bleeding procedure to see if you can eliminate the VLA noise? Its worth trying prior to tearing into the engine.
jrmdir Feb 17, 2017 12:56 PM
^^^ +1
Make sure you have fresh clean oil in the engine and then follow this:
Mitsubishi Tech - Minute Mod: The 5 Minute Lifter Noise Fix
Don't chase after other causes until ruling this out!
Ron
slinky Mar 4, 2017 11:46 PM
timing tensioner
I had to replace the belt, tensioner and components when I got my 03 tero. Looked like the belt and pump had been replaced but not the tensioner. Id recommend you look up the dayco set that includes the seals on rockauto. The dayco set is what AutoZone carries, but the one I got online was 50 bucks cheaper and included the front end seals, and a sticker to put on the frame for the date and mileage you changed it
