02 Montero LTD EGR
Old 03-07-2018, 08:23 PM
Default 02 Montero LTD EGR
im at a complete loss.
I threw codes for Injectore Fuel Pressure Regulator valve and EGR. Replaced both.
Threw a code the that insufficient EGR flow/ bank 2 running lean. Recommend that I get an EGR solenoid. Just replaced that today.
( rough idle too. But not showing on the tack)
Still throwing the same codes. Can someone please enlighten me as to what I do now? Or what might be the issue??
Old 03-07-2018, 11:50 PM
EGR flow malfunction may also be due to a problem with EGR valve itself, or obstruction in the EGR pipe. If your EGR valve is vacuum modulated - plug a vacuum pump into it and with engine at idle apply vacuum. The engine should stumble and die. If it does not do this - you have a problem with the valve itself or with the piping. Unbolt ERG pipe from the engine (driver side) and see if there is any crud obstructing things. Take out EGR valve from the manifold and make sure the hole in the manifold is clear. If the vacuum test works properly - check the vacuum hoses. You may have a cracked/disconnected hose that prevents actuation of the EGR valve. Having a cracked vacuum hose will throw the same EGR code as a bad solenoid or bad valve.
inbilya
14
08-30-2017 07:45 AM
coder562
11
08-13-2017 08:41 PM
Fergie
06-13-2017 12:04 AM
ninjaloops916
03-10-2014 09:01 PM
Daks
03-16-2012 02:51 AM
Quick Reply: 02 Montero LTD EGR
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
