02 montero limited No 4WD at all
New to the montero family , just bought a butifual 02 montero with a few small problumes im hoping some one can help me with. First thing is that unlike the other threads about the 4wd the indicator lights on my dash do nothing at all, only the back passanger weel is green at all times and when shifting in to 4wd nothing happens at all! and that brings me to my second problume wich is that when about 40 mph there is a sudden shimmy that seems to be coming from the back passanger weel(but im no macanic so it could be from somewhere else) if i go threw 40 to 50 it dont do it ,just when holding speed at 40-45 about , any one have any advise or ideas?
As far as lights on the lights on 4wd indicator, it sounds like you have burnt out bulbs. Probably more than one (left rear wheel, front wheels and possibly center diff too). Without relying on the indicator, put the shifter in 4HLC position. Drive forward for a little and then try to turn. If the vehicle "hops" and outside wheels spin through - than you 4wd is working, just an indicator is malfunctioning.
As for the shimmy you are getting, it is most likely due to unbalanced tires and its just worst at 40-45. Get your wheels re-balanced and you should be good there |
got the 4wd figured out it was a broken ground wire on the transfer case, but as for the shimmy it is still there and is not a tire, it is a sudden vary loud vibration that only lasts for 10 sec or so unless i decelerate or accelerate. have has the tire shimmy in my old Tahoe this is much worse
Originally Posted by marc
(Post 308160)
had similar shuddering issue on monty 2002...The vibration stopped after a Transmission flush...
