02 Montero Sport LS Loose Steering Problems
I love my 2002 and its been great for many years has 180k miles and i need advise on what to try. Front steering feels loose, mild pop sound when backing up turning corners. I have taken wheels off and inspected the lower ball joints did not see any damage though it still feels loose, no wobble. Two months ago just to see i had a front end alignment done but didnt fix. I have saved up $500 so i can afford work. Where do i go next replace both lower ball joints? plus alignment? repack wheel bearings? Thanks for your time and recommendations
The single pop when backing up and turning can be from worn tie rod ends. When they wear out they move about too much (rotate on the knuckle) and tie rod bumps on the frame. When you reverse that is when they rotate from one extreme to another. Its a pretty easy to check and replace them.
deziking
Aug 29, 2019 12:04 AM
jthorn75
Mar 30, 2013 03:18 PM
Lobosmom1
Sep 5, 2012 02:08 PM
