1994 3.5l Montero 2 row vs 3 row radiator
Hello everyone,
I need help on this issue. My 1994 3.5l Montero seems to overheat as it's driven in harsh environment with A/C on. What I found out what that V6 monteros all come with 2 row radiators. My questions is, what do you need to do to convert it to 3 row radiator? I would appreciate a detailed instructions, i.g. what parts need to be modified with what, etc? Thank you, MM |
What have you done to lead you to believe that you need a new radiator?
Have you tried pulling it and getting it rodded out? If you do make sure you do a complete engine flush (not a drain and fill). Both of these moves may save you the purchase. (I'm not even sure the radiator you are speaking of will fit as a bolt on...) Good Luck |
