2001 Montero Limited - ready for rebuild
Old Dec 12, 2023 | 07:53 PM
dckope's Avatar
Default 2001 Montero Limited - ready for rebuild
This 2001 Montero Limited was optioned with a Preferred Equipment package, which consists of automatic climate control with rear air-conditioner/ heater. Front intercooler and transmission cooler. Safety items of particular note are privacy glass, alarm/immobilizer system with panic mode and remote, dual-front and front-side airbags, and four-wheel vented-disc brakes with multimode ABS--one of the few in the industry in 2001 that identifies when you're on a loose surface and adjusts accordingly.
For comfort and convenience, this Limited model includes a seven-speaker 175-watt Kenwood audio system (aftermarket), power-operated windows/locks/mirrors/moonroof, leather front- and second-row seats, wood/leather steering wheel, and heated front seats and side mirrors. In terms of hard-core off-road essentials, ours was outfitted with the outstanding, true 4x4 system, skidplates, a complete, removable tool kit fitted to the swing-out rear "barn door," a locked and covered full-size spare wheel, high end foglights and massive tow hooks front and rear.
This vehicle has been WELL cared for and maintained with all systems and components functioning. Garaged for nearly 15 years of the 20+ ownership. Paint is in exceptional condition, Interior is in excellent condition. One owner.
If you are a Mitsubishi Montero enthusiast this vehicle would be a great base to work from but would require an engine refresh and transmission rebuild.
Why are we selling it? We no longer need a 7 passenger vehicle and were seeking a smaller more economic vehicle.
Message on pricing. Located in Bremerton Washington
Bumper skin was replace at 160K
Rim's and tires are still in good order
Interior is in excellent shape
Nothing broken here. Everything works
Kenwood stereo head unit is removable.
Digital Kenwood single slot CD stereo
Overall
Engine Type Gas
Transmission 5-speed shiftable automatic
Drive Type Four wheel drive
Cylinders V6
Total Seating 7 (2 bucket seat front, 3 person split bench middle, 2 person foldable jump seat in rear)
Fuel & MPG
Fuel type Premium unleaded (required)
EPA city/highway MPG 13/16 MPG
EPA combined MPG 14 MPG
Range in miles (city/hwy) 309.4/380.8 mi.
Fuel tank capacity 23.8 gal.
Engine
Base engine size 3.5 L
Cylinders V6
Base engine type Gas
Horsepower 200 hp @ 5,000 rpm
Torque 235 lb-ft @ 3,000 rpm
Valves 24
Cam type Single overhead cam (SOHC)
(Engine does leak oil at rear transfer case. Highly maintained and all major seals were replaced at $200K except for rear engine seal which requires pulling the engine)
Towing & Hauling
Max Towing Capacity 5,000 lbs.
Towing hitch bar
Drivetrain
Drive type Four wheel drive
On demand 4WD Standard
Hi-lo gear selection Standard
Center locking differential Standard
Rear limited slip differential Standard
(Transmission will need servicing. Currently first gear servo is failing and slips into neutral
Four-wheel independent suspension Standard
Dimensions
Length 188.9 in.
Overall width without mirrors 73.9 in.
Height 73.1 in.
Wheelbase 109.5 in.
Turning circle 37.4 ft.
Ground clearance 9.3 in.
Curb weight 4,675 lbs.
Maximum towing capacity 5,000 lbs.
Gross weight 5,840 lbs.
Front Seat Dimensions
Front head room 41.4 in.
Front leg room 42.7 in.
Front shoulder room 58.5 in.
Front hip room 56 in.
Leather Standard
Bucket front seats Standard
10-way power driver seat Standard
Height adjustable driver seat Standard
Driver seat with manual adjustable lumbar support Standard
Heated driver seat Standard
Heated passenger seat Standard
Rear Seat Dimensions
Rear head room 40.2 in.
Rear leg room 37.6 in.
Rear shoulder room 58.5 in.
Rear hip room 55 in.
Split-folding rear seatback Standard
Safety
Dual front side-mounted airbags Standard
Child seat anchors Standard
Rear door child safety locks Standard
4-wheel ABS Standard
Front and rear ventilated disc brakes Standard
Electronic brakeforce distribution Standard
Auto delay off headlamps Standard
Front fog/driving lights Standard
2 front headrests Standard
2 rear headrests Standard
Rear center lap belt Standard
Remote anti-theft alarm system Standard
Engine immobilizer Standard
In-Car Entertainment
JVC AM/FM Digital 1 Slot CD stereo with removable face plate (aftermarket)
175 watts stereo output
7 total speakers including rear subwoofer
Electric antenna
Power Feature
1 one-touch power windows Standard
1st row power glass moonroof Standard
Power door locks Standard
Power mirrors Standard
Heated mirrors Standard
Comfort & Convenience
Tilt-adjustable steering wheel Standard
Speed-proportional power steering Standard
12V rear power outlet(s) Standard
Cruise control Standard
Front, rear and 3rd row cupholders Standard
Front door pockets Standard
Front seatback storage Standard
Retained accessory power Standard
Leather and wood steering wheel Standard
Single zone front air conditioning Standard
Dual vanity mirrors Standard
Rear floor mats Standard
Simulated wood trim on dash Standard
Simulated wood trim on center console Standard
Simulated wood trim on doors Standard
Front and rear reading lights Standard
Instrumentation
Digital Compass Standard
External temperature display Standard
Tachometer Standard
Clock Standard
Tires & Wheels ($3,200 value)
21 x 9.0 in. custom chrome rims (Less Schwab)
P285/40 R20 Toyo Proxes All Season low profile tires
Fullsize spare tire with cover
Bike Racks ($600 value)
Thule T2 Duel roof bike rack with locks
Old Dec 12, 2023 | 11:44 PM
It is in remarkably good condition for 300k Mike's. You've done good job with the upkeep.
Old Dec 13, 2023 | 12:33 PM
dckope's Avatar
Thanks Hunter. It certainly has alot more life for the right person who can update the transmission and refresh the engine. Unfortunately I'm not in a position to do that.
thestones94
Mar 6, 2010 12:42 PM
Kelly3s
Jan 5, 2009 09:50 PM
