2001 Montero Sport - Rear Brake Question
Hi All,
I need to replace the rear brake pads on a 2001 Montero sport. Is a special tool needed to compress the calipers? I have a tool that compresses the pistons that I used on the front, does the rear work the same way? I only ask because I used to have a car that needed the rear caliper pistons to be "screwed" back in. I needed a special tool that fit on a socket for that. Just wanted to make sure I had the tool before I took the brakes apart. Thanks, George |
RE: 2001 Montero Sport - Rear Brake Question
If it is the same as my 02 full size then all you REALLY need is a C-clamp and your used brake pad for a flat surface. Same as front.
ORIGINAL: FireDoc If it is the same as my 02 full size then all you REALLY need is a C-clamp and your used brake pad for a flat surface. Same as front. Thanks Doc! George |
