2002 idles badly when D engaged
Old Sep 28, 2023 | 07:33 PM
ProfJ's Avatar
Default 2002 idles badly when D engaged
Hi Folks,
2002 Montero Ltd with auto box. It idles fine in P and N, but when I engage D, it starts to miss and run badly - never quite dies. When I accelerate, it misses a few beats before getting smooth. All fluids at right levels, plugs etc. quite recently changed. Any suggestions where to start?
Thanks,
Jon
Old Sep 28, 2023 | 08:44 PM
My first instinct would be fuel system - fuel pressure, etc. It sounds like its not getting enough when under load. Easiest way to see this is to hook up a scanner with live data stream. Then you can see if there is a big chamge in fuel delivery when engine is under load (in D)
Old Sep 28, 2023 | 08:47 PM
ProfJ's Avatar
It seems likely that an idle fuel circuit is not delivering - the pump etc must be ok, because there are no signs of fuel starvation at high speed. How do I diagnose idle problems?
jmccollum17@gmail.com
Jul 12, 2016 04:53 PM
arrowboy107
Mar 31, 2015 05:53 PM
saamii
May 23, 2011 10:41 PM
tomo320
Nov 16, 2010 11:31 PM
hotponyshoes
Jul 4, 2010 05:43 PM
