2002 Montero Limited Oxygen Sensor Problem
Hello. I recently purchased a 2002 Montero Limited. Has a 178,000. Previous owner told me one of the oxygen sensors were bad. As I was checking the fluids, I noticed the MAF was unplugged, plugged it back in and seemed to run fine. After driving it for 30-45 min it started to shudder in 5th gear really bad. Pulled over, restarted and it didn't shudder. Drove another 10 min or so and it started shuddering again. After I made it home, I unplugged the MAF and it ran much better and the shuddering disappeared. I cleaned the MAF and plugged it back in and so far it seems to run ok with no shudder, but it is throwing 5 o2 sensor codes:
p0155 p0134 p0135 p0141 P0132 With the MAF plugged in, gas mileage is horrible and the exhaust smells pretty bad. Could a bad MAF trigger these codes? Or could something else be causing this? Thanks! |
Originally Posted by big_country01
(Post 315183)
Thanks for the reply! I going to check the ohm out the o2 sensors to see if they are good or bad. With so many codes being thrown and assuming after I check the o2 sensors and they are good, could it be possible the ECM is bad?
Wouldn't jump to that conclusion. Check voltage on O2s and make sure the wiring is good. Also, since MAF could be an issue - check that too. Test voltage and make sure you get change when engine runs at different RPM
I checked the all o2 4 sensors. 3 sensors did not ohm out and they correspond to the codes being thrown. Checked the voltage at all 4 plugs and they are receiving 12v. Haven't checked the MAF yet but will tomorrow.
