2002 Montero sport ES V6 idle control valve
I keep having to change out the idle air control motor about every couple of months. Has anyone else experienced this and what did you do or what causes this?
Idle Air Control Valve
Originally Posted by tonybrooks625
(Post 327282)
Do I just need to bite the bullet and spend several hundred dollars for a factory replacement IAC? If I could get another cheap one to last four years I would be happy with that. |
Junk Yard
Just grab one at a junk yard dude.. Tough to find Monteros in the JY tho so good luck bud.
Have you done proper Idle re-learn procedure after replacing IAC? Agree with previous post - go with Mitsubishi part, not aftermarket!!!
