2003 Mitsubishi Montero Code 35
Hi, I received a code 35 on my montero. At first it was a code 41 that meant the O2 sensors which I have already replaced twice and my friend was able to finally clear that code but now I get a code 35. What could this mean? It has to do with the transfer case he said. What do you think? What could it be?
Thanks -Marie |
Do you have the complete code P0xxx? I am not aware of two digit codes...OBD-II (your onboard diagnostic system) has codes like this - P0135 - which refers to a Bank 1 O2 sensor. P0041 refers to your downstream O2 sensors.
Were the codes pulled from another componenent like the tranny? |
code 35 or other 2 digit codes can be found in the ABS system. this will also give you codes for the transfer case.
