bvolks |
04-05-2016 04:23 PM |
2003 Montero shifter cable
Has anyone ever replaced the shifter cable on a 2003 Montero Limited (automatic transmission)? I'm attempting to change one for a friend and I can't figure out how to get at the 2 bolts on the underside the tunnel just in front of the shifter itself. I can see the back of the studs from the inside but I can't even get my hands between the transmission and floor to feel them from the bottom. We've adjusted it several times and we can either get it to go into park but not drive or drive but not park so we assume the cable must be stretched.
Also, the starter won't engage when you turn the key anymore, not even a click. We hooked a jumper wire to the starter and it will start that way. I thought it might be an issue with the alarm but I've deactivated it like the owner's manual says and still nothing.
