2003 montero sport crank shaft pulley pin?
Old May 15, 2012 | 12:35 AM
jonathon75's Avatar
Default 2003 montero sport crank shaft pulley pin?
My belts keep slipping and I finally discovered the crank shaft pulley bolt was responsible. The bolt continues to loosen. I had it tightened to specifications but still loosens. I noticed there was a small hole in the pulley and have read that a pin belongs there to stop the pulley from turning. Is this true? If so where do I find it because it isn't offered with the pulley? Is there a new bolt that is offered because of so many previous recalls? Ill never buy another mitsubishi. Too many problems.
Old Jun 4, 2012 | 01:52 PM
jonathon75's Avatar
anyone?
Old Jun 5, 2012 | 12:40 AM
mxmikie's Avatar
its a roll pin you know any hardware store
Old Jun 2, 2013 | 03:37 PM
Media001's Avatar
Hello Everyone- I'm having the same issue with my Montero Ltd. My crankshaft bolt keeps getting loose and i'm suspecting its from the roll pin to the damper pulley - took it apart and notice the roll pin is sheared off.
Anyone have any thoughts to the original post about the pin?
Thanks
deadreckoning86
Jun 17, 2014 12:36 PM
Danestes
Mar 11, 2011 10:16 AM
Wingo171
Aug 20, 2007 05:38 PM
jlozano3k
May 15, 2006 05:51 PM
Timmay
Sep 26, 2005 06:15 AM
