| jonathon75 |
May 15, 2012 12:35 AM |
2003 montero sport crank shaft pulley pin?
My belts keep slipping and I finally discovered the crank shaft pulley bolt was responsible. The bolt continues to loosen. I had it tightened to specifications but still loosens. I noticed there was a small hole in the pulley and have read that a pin belongs there to stop the pulley from turning. Is this true? If so where do I find it because it isn't offered with the pulley? Is there a new bolt that is offered because of so many previous recalls? Ill never buy another mitsubishi. Too many problems.
