4WD light keeps on blinking
I have a Mitsubishi Montero Sprt 2000 LS 4wd and lately the 4wd indicator light at the dashboard starts blinking as soon as I start the car even though it's on 2H, the car drives fine and the check engine doesn't turns on. The 4WD works fine since I've used it a few times. I am hoping to get an advice or someone had the same problem in the past, it's just very distracting, please help!
Welcome to the boards. Just posted this in another thread:
Originally Posted by Skiddy
(Post 256669)
As for the blinking 4WD lights, it's mostly likely the front drive axle solenoid valve (part number: MB620532). Do you have a hand operated vacuum pump? Might want to check if it's holding vacuum.
