4x4 works but frnt selec lights blinking? (95' montero SR)
Old May 7, 2014 | 12:18 AM
shownuff80's Avatar
Default 4x4 works but frnt selec lights blinking? (95' montero SR)
Hi im new to the forum and have reserched but couldnt find the same issue im having. First off my selec trac rear lights dont come on at all and when I engage 4wd the D/L orange light comes and stays on (front) which i think is normal but the two front green lights just blink. Ive put it in 4wd in soft sand and gassed it and the front wheels do spin so im confused. when I go to 4LHC and push the rear locker button I hear the compressor working and then the rear middle orange light clicks on and stays on so i know that works but why is the front green lights blinking if 4wd is working?? any help would be awesome thanks.
Old May 11, 2014 | 07:07 PM
shownuff80's Avatar
Just checked my freewheel switch and its ok but checked the ohms on my solenoids and the yellow dot one is at 41 and the bue dot one is at 128 so im thinking i found my problem.
Old May 12, 2014 | 08:55 AM
Sounds like you are on the right track. I was going to suggest to check solenoids, because it sounds like the front wheels may not be fully engaged and therefore the computer not getting the information that the process is completed. Let us know if replacing the solenoids worked.
Old May 12, 2014 | 06:19 PM
shownuff80's Avatar
Ya that sounds like that could be the problem. As soon as i get the part and installed I'll let post the results thnx.
Old May 12, 2014 | 06:21 PM
shownuff80's Avatar
O ya and the two rear green lights werent coming on because the bulbs were burnt out. easy to check and replace.
ole
19
Jun 10, 2015 10:47 AM
95 diamante
Sep 17, 2009 10:42 AM
rjr325
Feb 8, 2009 06:14 PM
salis
Oct 22, 2008 05:04 AM
ultramindbrk
Jul 29, 2007 03:07 PM
