-   Mitsubishi Montero & Montero Sport (https://mitsubishiforum.com/forum/mitsubishi-montero-montero-sport-14/)
-   -   90 mighty max v6 (https://mitsubishiforum.com/forum/mitsubishi-montero-montero-sport-14/90-mighty-max-v6-45329/)
m80glostick Oct 15, 2013 06:42 PM
90 mighty max v6
hey i have a 90 mighty max v6 4w4.
same motor as the montero,
im getting no spark at all, started with getting spark most of the time.
now none of the time.
replaced distributor.
replaced ignition coil.
replaced icm.
have not replaced ecu or the little resistor thingy in line with the coil.
where should i check for what else could possibly be wrong with vehicle?
if i ground the solid white wire off the icm i get spark. which means im not getting a signal from something correct? if ther happens to be some magical relay or fuse i missed someone please tell me, would like to have truck for winter.
mxmikie Oct 15, 2013 10:15 PM
any burnt caps in the ecm ???
m80glostick Oct 16, 2013 06:38 AM
Have not taken the Ecm of truck to look. Geussing something I should do
m80glostick Oct 17, 2013 12:41 PM
Ok how do I post a pic of the ecu?
I believe it to be burnt out the chip in the center has black marks all around it.
Anybody have one? Or know where to get?
