90 MONTERO brake, turn sig, cruise control issue
Old Jul 13, 2007 | 11:14 AM
FLYONWALL's Avatar
Default 90 MONTERO brake, turn sig, cruise control issue
I have checked what I thought were all the fuses in the pass compartment, and the 3 on the battery and cannot locate the fault. I have running lights and all other lights, and every other function of the electrical works correctly. Only still no turn sig, cruise, and stop lights.
Options?
Thanks for your help!
Old Jul 13, 2007 | 04:26 PM
Manybrews's Avatar
Default RE: 90 MONTERO brake, turn sig, cruise control issue
melted wiring by the muffler.
unless you have a badly corroded trailer harness due to poor installation.
Old Jul 13, 2007 | 05:02 PM
off roader's Avatar
Manybrews is probably right on the wiring issue. Having a fault in the brake light system could stop the cruise control from working. I suspect it uses the brake light signal to disable the cruise control whenever you apply the brakes.
Also if you've installed anything in the engine bay that's not a standard item, it may have worn through a wiring harness. That's what happened on mine and the symptoms I had were the high & low beams were reversed... (I'd get high beams when the switch was in low, and vice versa.)
Old Apr 28, 2013 | 01:57 PM
Bottom Feeder's Avatar
Options?
All the issues you have described are controlled by the "Hazard" switch. you either need to replace or clean the contacts on the switch. It is easy to clean so I would try that first.
Rich
Bob3905
Feb 22, 2015 06:42 PM
MattSelkirk
Jul 7, 2012 05:53 PM
tmking66
Mar 22, 2012 03:30 PM
3000gt1999
Jan 10, 2007 02:29 AM
sandhillscapital
Sep 11, 2004 01:22 PM
