-   Mitsubishi Montero & Montero Sport (https://mitsubishiforum.com/forum/mitsubishi-montero-montero-sport-14/)
-   -   96 Montero LS 3.0 VSS (https://mitsubishiforum.com/forum/mitsubishi-montero-montero-sport-14/96-montero-ls-3-0-vss-53171/)
meclipsegt 04-30-2019 06:16 PM
The VSS itself works. Speedo works, but ECU doesnt show anything. so, Im looking at the FSM (13A-1076-1) and the VSS plug they show is a 2 wire, but the truck is a 3 wire. So, how do I test the wire for a ground to ECU then? Which wire goes to ECU pin #86 (thats what the FSM says, I hope its correct)? Thanks in advance.
1960StudebakerHawk 05-06-2019 04:49 PM
What is a VSS?????
Your post is a bit vague.....what is the issue in more detail?
HunterD 05-07-2019 11:23 PM
Vehicle Speed Sensor? Yeah, more details please. You sure you got FSM for the right model/year?
meclipsegt 06-26-2019 09:22 PM
Yes, vehicle speed sensor. And yes, I have a 96 and http://www.mitsubishilinks.com/ has one for a 96. Not sure what else I need to say, I need to troubleshoot the vehicle speed sensor and wiring. Gauge works, but ECU shows 0 for speed all the time. Cant smog it till its fixed.
Monterooooo 06-29-2021 07:16 PM
Did you figure this out? I have the same problem
