97MonterSport questions
It has been a little while since I have been out here but have a couple of questions. First is the button on the Dash, A/T mode, what is it. I do not have the book, the previous owner lost it. Does anyone know of a issue with the Steering column on these vehicles from the factory. I have a shake in the steering wheel that feels like something is loose. I have replace the inner/outer tie rods, the pitman arm on the psgr side, the drivers side does not seem to have any play, replaced the bearings on the psgr side, which I do believe did not need to be done and replace the tires which were worn. Of course the alignment was done.
RE: 97MonterSport questions
Follow the link on my signature and you'll find tons of information you're looking for. Read the FAQ that i wrote up before you start browsing! Good Luck!
Joel, CA |
