98 Montero TPS settings?? Please Help
I have a '98 Montero Sport V6. I just had to replace the Throttle Position Sensor and need to know how to adjust this?
Which of the 4 wires do I read off of with a meter and what "numbers" am I looking for? Thanks so much, in advance. Jeff |
I bookmarked this some time ago. Not sure which Mitsu model it is for but most of the diagrams are identical to those in my factory manual for my '99 3.5V6.
http://www.3si.org/wiki/index.php/TP...sor_Adjustment Hopefully some or all of this info will apply to your Sport. Good luck. Ron |
Now I recall - that instruction link is for 3000GT. Hope the wiring set up is the same. Again. The instructions in my manual are very similar.
Thanks for the link. I will give it a try.
-Jeff |
Hellow folks. I have a Montero 1998 V6 3000. Would you know where could I find a manual with mitsubishi codes for parts and pieces and respective exploded drawings? I'd like to order some replacements from US (I'm in Brazil)and need this code to avoid mistakes. Additonally could you recomend me some parts suplyers there? thank you very much. Antonio
