99 Montero Alternator Fuse?
99 Montero Sport, where is the alternator fuse link located? New battery and alternator but car dies after running a few minutes. Recharge battery, starts and runs until battery is drained. Alternator tested okay, told there is a fuse link that may be blown. There is a fuse panel on fender under hood, not sure what I am looking for.
Any help would be appreciatted. Thanks |
It will be under the hood in the fuse box you can check it there bad by looking through the top be shure to pull them out and check for corrosion on the pins.
here's what they look like. http://www.autozone.com/autozone/par....diyprod4-b2c7 |
Fuse looks good, could not get it to pull out. Do I need to loosen the screw on the side?
yes u do. if that fuse isnt blown, get somebody else thats competent to check your alternator output. usually oil leaks onto the alternator and slowly kills it. VERY common on montero.
