99 Montero Sport Belt Change Help
Old Mar 1, 2008 | 06:40 PM
crash94's Avatar
Default 99 Montero Sport Belt Change Help
Does anyone know of a how to thread to help change belts on a 99 Montero Sport? I've searched and also gone back to page 13 until I gave up.
If there's no thread some guidance on how to would be greatly appreciated.
Thanks for the help!
Jason
Old Mar 3, 2008 | 02:40 PM
Liquid_force's Avatar
Default RE: 99 Montero Sport Belt Change Help
accessory belts?
You have to loosenall 3 tensioners which is just a matter of loosening the bolt at the center of each pulley, then loosening the bolt on the tensioner itself. Two tensioners can be accessed from the top, but the alt tensioner has to be accessed from the bottom. It is a little tricky to get them around the fan, but anybody can figure it out.
Getting the tension set at reinstallation can be a little tedious, but no big deal.
Old Apr 4, 2008 | 08:14 PM
crash94's Avatar
Is there a guide or rule of thumb so I'll know their tight enough or not too tight?
Jason
Old Apr 6, 2008 | 10:44 PM
I've never used anything other than feel and common sense.
If they're functioning properly now (not slipping/squealing), give them all a tug so you know about what the ideal tension is.
If they're too loosethey'll squeal.
If they're too tight it can acceleratebelt, bearing and accessory wear.
GAMonteroSport02
Nov 20, 2017 10:51 PM
joeinmn
Jun 14, 2015 04:14 PM
marx88
Jun 30, 2011 03:54 PM
mantis270
Dec 15, 2009 10:34 PM
toddyfresh
Nov 26, 2006 07:20 PM
