ABS Pump 2004 Mitsubishi Montero
I recently changed my ABS PUMP BRAKE BOOSTER HYDRAULIC MOTOR... prior to replacing the alarm went off and the dash lights lit up like a christmas tree. Now I can't get rid of a humming sound and what seems like a turkey gobbling in my engine... What is going on?
That means… accumulator, hbb/abs pump motor, right? Or no?
did the bleeding procedure, drive for the ECM to read, check the abs relays and fuses, check the wiring |
| All times are GMT -5. The time now is 01:51 AM. |
