AC clutch bearing, '94 Montero LS
Old Jun 19, 2007 | 08:49 PM
jim rage's Avatar
Default AC clutch bearing, '94 Montero LS
Hello.
Like the subject line says, the AC clutch bearings went bad -- bad to the point of grinding metal. I ended up pulling the belt off to keep from completely destroying the bearing housing. Is it possible to remove the AC clutch without pulling the whole compressor?
TIA!!!
^JR^
Old Jun 20, 2007 | 06:00 PM
Manybrews's Avatar
Default RE: AC clutch bearing, '94 Montero LS
it comes off seperately, but may not be easy after years of corrosion have set in.
Old Jun 20, 2007 | 06:49 PM
jim rage's Avatar
Thanks.
Is there a mitsubishi-specific tool I'll need? Or should I be able to rent one from autozone?
^JR^
Dafatboy
Jul 14, 2015 06:06 PM
happyharold4
May 2, 2011 10:32 PM
Christian
Mar 8, 2009 01:17 PM
lovinmrv
Dec 30, 2008 09:21 PM
lloydjv
Mar 26, 2007 03:36 AM
