Ac not working
I have no power to the compressor. The freon checks OK 100 psi . any ideas? O yea the 25amp fuse is good also.
I don't think that is the right fuse. You need to check fuse #19 (10A) in the engine compartment. That one is responsible for the AC system.
I checked #9 OK. What about relay #f. swopped # c, d. they are OK. But f is different.I checked the three wires going to the comp. And no power to any of them.
Originally Posted by 2001 montero
(Post 309942)
I checked #9 OK.
If that checks out, check if you are getting power to the ac relay (if you know which one it is). You can also bypass the relay and see if you get juice on at the compressor. |
Got it working! The problem was the #f relay. I just took a chance and replaced it. Thanks for your help.
