another timing belt question
first time poster but been browsing the forum for a while, my question is i just change my timing belt ,my camshaft sensing blade and camshaft sensor on my 2002 montero sport with 3.5 engine, i believe i timed everything right interms of the crankshaft sprocket two camshaft sprocket to the topdead center, now the problem is the crankshaft pulley is not timed(it's way past the T mark) to the timing mark bracket that's mounted on the accesory mount assembly(the big metal cover). the car starts right away but when i test drive it it seems there's no power, do i need to timed my car using a timing light, any answer is really appreciated, thanks
Follow proper proceedure
Hey just download service manual from http://www.mitsubishilinks.com/
and just follow instructions. Do it EXACTLY as it says in manual. Good luck. |
