| Zcshields |
Nov 4, 2022 08:45 AM |
Bank 2 Sensor 1 Removal Help
Hello everyone, I’m new to the forum and the new owner of a 2006 Montero 3.8L with 230,000 on it. Maintenance on it had been neglected for a long time, but I’m slowly bringing it back to life. I have finally stopped all the oil leaks (I think) and got the CEL off by doing valve covers, rear cam o-rings, butterfly valve shaft o-ring, and all new oxygen sensors. The only thing I have left for this job is the b2s1 (drivers side upper) oxygen sensor. I can’t for the life of me figure out how to go about removing it. I had to use a breaker bar on the others, and I can’t find a way to get a wrench in there to even attempt to turn it. Any help would be greatly appreciated!
https://cimg8.ibsrv.net/gimg/mitsubi...b39940c01.jpeg
Here she is! Up next I’m tackling the flashing 4x4 light and front differential fluid change. I have replaced the freewheel clutch switch, but I believe my problem is the actuator itself. I plan to post anything interesting or helpful that I find out along the way that hasn’t already been covered.
