change oil pump or not
Old Apr 9, 2008 | 09:30 PM
SyntorX's Avatar
Default change oil pump or not
I am rebuilding my heads...my friend thinks I should change out the oil pump "while I'm in there". I am going to do the water pump, but should I change out the oil pump as well???
It is a 2002 Montero Sport 3.0liter SOHC with 99,000k miles
I bought it as is. I know NO history on the vehicle, it just dosen't run. it had clean oil in it and the radiator was full of coolant.
After the purchase:
I do know the driver side head is warped and is being replaced... the cam siezed/froze up.
Thanks for any input or comment!
Old Apr 10, 2008 | 12:28 AM
Joel_CA's Avatar
Default RE: change oil pump or not
If you're going that far- you might as well do it for added insurance. Note that it is a significant amount of work you are adding ESPECIALLY if you have a 4WD model. Removing the pan (neccesary when replacing the oil pump) will be a pain in the *** with the front diff in the way. Not so bad with a 2WD.
JJ
Old Apr 22, 2008 | 11:18 AM
COMP's Avatar
so what did you do ???
Old May 7, 2008 | 10:43 PM
SyntorX's Avatar
I did not replace the oil pump. I had the heads rebuilt and after I put it all back together, I started it up and there is a TICKING NOISE ON THE DRIVER SIDE!!!
I do not want to take it apart and check the valve lash.... Does anyone have any ideas on what I should do??
Mike
Old Jun 10, 2008 | 09:30 AM
tdf's Avatar
tdf
I know you are frustrated over the "tick", but you won't sleep well until you check out why you have one. Valve lash would be a good place to start.
MNalfa
17
May 9, 2019 06:07 AM
Vadimus
Nov 26, 2010 12:13 PM
chelsel
Oct 8, 2007 09:30 AM
blamesociety
Nov 2, 2006 08:45 PM
newspeed
Nov 8, 2005 06:21 PM
