Compass Help!
I have a 97 Montero and the Indaglo light has gone out! It still works but at night you can not see the compass. Is this just a light bulb that went out or is this bad? I hope it is an easy fix! Any help is appreciated!
RE: Compass Help!
There is a bulb in there, but the dealer will have a very difficult time looking it up. I suggest you go in there and remove the bulb so they can match it. If not from the dealer, try an auto parts store to match it up with.
Joel |
RE: Compass Help!
Thanks, Joel i will do that.
RE: Compass Help!
I've actually had to replace one of those before and the bulb is similar in size to a Maglite AA bulb.. it might be a difficult find. The dealer parts guy has to really know his stuff to be able to find it in the CAPS catalog. Good LUck!
Joel, CA |
RE: Compass Help!
Hello,
I have a 98 Mitsubishi Montero. When I start the engine the compass is always showing a letter "S" rounding the screen. Anybody can help me? Regards, |
RE: Compass Help!
I found the solution in another forum. You have to press the "S" button and then make a 360ยบ with the vehicle and thats'it
RE: Compass Help!
Joel-
I finally took it apart and there were two lights in the back of mine. Did yours have two? |
RE: Compass Help!
Hmm.. i don't remember exactly. It was several years ago and was a customers car. I just remember having to jump through hoops just to get the right part.
Joel, CA |
