Crankshaft Pulley Bolt
Old Nov 30, 2021 | 07:13 PM
  #41
Pepe420's Avatar
Default Hey get you a brakes bar 1/2 inch better but 3/8 works fine put on crankshaft bolt
Originally Posted by turbobuick1
Is there anyone with experience on removing the crankshaft pulley bolt above? I have a 2001 Montero Sport and my impact wrench is not budging that front crank bolt. I'm thinking about springing for a stronger impact but the thought of the bolt breaking is not a pleasant one. Any help would be greatly appreciated....
Hey get you a brakes bar 1/2 inch better but 3/8 works fine put on crankshaft bolt from underneath wedge against frame and turn the engine over ,walah done and done!
Old Nov 30, 2021 | 10:49 PM
  #42
The very first time I removed my crankshagt pulley bolt, i used this technique. Use a BIG breaker bar or (1/2" min). Make sure it rests squarelt against tbe fender and doesn't have any place for rotation. DO NOT HOLD IT with your hands. You dont need to start engine. Just turn key to engage starter just a bump) and turn it off immediately. You'd be surprised how effective this is.
Old Dec 18, 2021 | 02:46 AM
  #43
destey's Avatar
Dont use the starter, that is hack job-ish. Risking breaking something. Just use a 1/2" breaker bar with a pipe. And buy a new bolt for putting back in, there's too much load on the bolt undoing it to use it again.
Old Dec 18, 2021 | 09:51 PM
  #44
Naeos_Valkarian's Avatar
This is the safe answer for sure but there have been a multitude of people I've talked to over the years that have re-used the bolt (even myself). I have had to remove the crank-pulley bolt like 10 times over the last few years to do various odds and ends and I have reused it every time with no issues. Just make sure the threads are clean on the bolt and in the hole, and torque to spec. Also make sure your VIN isn't in the crankpulley bolt recall, if it is, replace the bolt.
Anthonyandrew
Jan 24, 2014 10:15 PM
Justin C.
Dec 12, 2011 03:38 PM
jacek
Dec 25, 2004 01:26 AM
LIQUIDSMILE
Jun 16, 2004 04:36 PM
03eclipseGT
Oct 6, 2003 08:43 PM
