MitJsus |
11-08-2010 07:27 AM |
The washboard feeling is referred to as transmission shudder. I would bet on this being your issue. I'm not an expert on transmissions, but I believe it is related to the torque converter. I had this issue in a Lincoln Town Car once. A transmission fluid and filter change, along with a bottle of Lubegard Automatic Transmission Protectant solved my problem. If you use Lubegard, you should check to make sure it is safe for Mitsubishi transmissions. I believe there are other things (electronics) that can cause transmission shudder besides your ATF and filter.
