Error codes PO182 & PO405, inaccurate gas gauge.
Old Mar 30, 2014 | 03:15 PM
azsungal77's Avatar
Red face Error codes PO182 & PO405, inaccurate gas gauge.
Where is the fuel temperature sensor? According to the codes could have some faulty wiring or connectors on EGR and this sensor. Still don't know how this figures with a gas gauge that can't make up its mind how much gas is in tank. Have performed resistance readings on new fuel sending unit and checks fine, but harness does not light 3.4w bulb nor move needle to half. Says to check certain connectors I am having trouble locating. Any help in appreciated. All other gauges work fine.
Old Mar 30, 2014 | 10:06 PM
mxmikie's Avatar
is this a 1990 montero ???
Old Apr 11, 2014 | 07:17 PM
azsungal77's Avatar
Default It is a 2002 Montero Ltd
It is odd all three have low circuit problems. When test light is hooked to harness of fuel level sensor, it does not light at all nor does it move the needle to half way. Then codes pop up PO403 and PO182, both showing low circuit. Any help?
Old Jan 16, 2017 | 03:37 PM
chewy705's Avatar
i have the same problem in a 2005 3.8lt montero. fuel temperature sensor low circuit code P0182.and i dont know where is located the fuel temperature sensor, any help please
CaptainDon
Nov 16, 2013 03:00 PM
CaptainDon
Nov 16, 2013 02:43 PM
DNA2112
May 12, 2005 10:47 AM
get435
Oct 17, 2004 10:09 AM
