fuel pump
i dont have any power to fuel pump anyone have any help
Originally Posted by rich lapham
(Post 269648)
Did you make sure that you it is a fuel pump? How many miles car have, and do you have a knowledge that car had the fuel pump ever replaced? Did you check the fuel pressure? Get a help from someone, to turn on/off ignition few times while you lean your ear on the opened gas tank and you should hear a noises when the keys turns to on position. If its silence ...its dead. Do u get any power inside of a vehicle when you turn the the key to on position? |
fuel pump
i took the covers off and got to the sending unit and checked the plug going in i also checked the fuses in the box aswell as under hood
by the way im new to this site and want to thank you for your help
(Post 269683)
Let me know. |
2002 montero ls i found were the pump is i cant find the fuel relays for it i have no power to the pump as far as i can tellthanks for the help
(Post 269762)
Here is what I got for your model. I uploaded it to my rapidshare account. Since files are too big to be posted here. Last one is "fuel pump replacement" applies to your vehicle too...its for mine.2001.LS. Overview " relay is at the "Q" Location: http://rapidshare.com/files/45076265...w_Location.pdf Fuel_pump_relay "Q" location: http://rapidshare.com/files/45076226...pump_relay.pdf Testing the realy: http://rapidshare.com/files/45076395..._the_relay.pdf Fuel pump replacement: http://rapidshare.com/files/450762257/fuel_pump.pdf |
hi zoza i want to thank yo for all the halp it was great im gonna try this
(Post 269828)
Let me know if you need any other service manual. Good luck! |
