Getting multiple codes (P0134, P0340, P0401, P0403, P0431)
Old Jun 14, 2013 | 02:19 PM
Dhanu's Avatar
Smile Getting multiple codes (P0134, P0340, P0401, P0403, P0431)
Hi,
I bought a 2002 Montero Limited few days ago and the 'Service Engine Soon' light was on. So I got the codes from an Autozone. There were 9 codes total, but he said some of them were duplicates.
This is what I got.
P0134 - Cylinder 1-4 heated oxygen (front) sensor no activity detected
P0340 - Camshaft position sensor (CMP) circuit
P0401 - EGR insufficient flow detected
P0403 - Exhaust gas recirculation (EGR) control circuit
P0431 - Warm up catalyst efficiency below threshold - cylinders 2-3
What could be the reason behind all of these codes? Is it like a single sensor or one part causing multiple codes?
Any help appreciated.
Thanks in advance.
PS : This is my secondary moving things/ snow days backup vehicle. So I'm not worried about things like fuel efficiency. Just wanted to make sure that it won't break down in the middle of the road.
Old Jun 14, 2013 | 02:33 PM
Check your ECU. Remove your ECU, yank off the cover, and look for damage.
When it spits out that many codes, it usually means it's toast.
Old Jun 14, 2013 | 02:42 PM
Dhanu's Avatar
Thanks for the reply.
So you mean there would be visible burn marks on the unit?
Now I'll have to find a youtube video to see where the ECU is located
Old Jun 14, 2013 | 04:09 PM
Here ya go: http://www.justanswer.com/mercury/3a...ero-sport.html
And yes, you will either see burn marks or on the reverse side, you will see where the pins have been soldered on they are a different color than the rest. This means heat, and heat is bad in electrical components.
Old Jun 14, 2013 | 04:12 PM
Dhanu's Avatar
Thanks.
Old Jun 4, 2017 | 07:19 PM
yatin_ash's Avatar
I know its a old post but was that really your ECU or the CAT causing all of these codes ?
Old Jun 4, 2017 | 11:54 PM
Those codes are for different circuits and it is likely that all the codes were true. Since there is a "no activity" code and "circuit fault" code, I'd guess it can be a damage to a wiring harness. It would be nice if OP could reply what the solution was.
Old Jun 5, 2017 | 01:55 PM
Dhanu's Avatar
The engine became as loud as a tractor, so I had the Camshaft position sensor, timing belt, serpentine belt, plugs/wires changed, and that was fixed. The light was still on. Given the price of the vehicle I didn't want to invest too much money in it, so never bothered to really look into the lights. I used it in the same condition for another 3 years and sold it off.
Sorry I can't be anymore of help to you :-)
Good Luck!
Old Jun 8, 2017 | 01:06 PM
yatin_ash's Avatar
no worries. Thank you for your input & time.
TDM556
May 2, 2021 09:52 PM
BamaMech101
Jun 5, 2017 11:08 PM
Mpzent86
Jan 26, 2012 09:52 PM
rford69
Apr 8, 2011 09:08 PM
wrkrbee
Oct 24, 2010 07:48 AM
