Dang, Sloop, sounds like it's better than fixed. Thanks for the -30-
Thanks for the update. Glad it was an easy fix.
Originally Posted by mothman52
(Post 271341)
Sloopjoshc wote:
And fancylady, welcome to the forum! So you said you fixed the problem but you haven't fixed the problem? So is your grinding still happening? If they replaced your CV joint then you probably have a bad bearing. Jack your wheel off the ground and see if you can make it grind as you spin it, then grab it by the edges and push and pull it towards then away from the car. If it's bad, you should feel looseness and hear a grinding noise or a metalic "thunk." I believe im gonna try that, thanx again for your replies. |
Ok, FancyLady, let us know how it goes. If that's not it then we can move onto some other diagnosis...
Good luck! |
