HELP: can’t get out the front cam seal on 3.5, it’s REALLY in there, photo included
Hello my dear forum, I’m again seeking your help.
I decided to replace front cam seals in my 1999 3.5 Montero, and I was able to remove the driver side cam seal, but the passenger one is REALLY stuck, I’ll attach pictures. It’s fully detached from cam at this point but I can’t for the life of me get it out! I tried penetrating oil, tried seal picks (broke instantly) I had success on the driver side with one of those keys to open paint cans, but on passenger side it’s just not going anywhere. Please check the pictures. I have a family trip in a week and desperately need a car! https://cimg9.ibsrv.net/gimg/mitsubi...26b3d5340.jpeg The seal is not attached to the camshaft as you can tell, and the wire is fully exposed, but the thing just won’t go https://cimg0.ibsrv.net/gimg/mitsubi...ff4b62a38.jpeg The seal is not attached to the camshaft as you can tell, and the wire is fully exposed, but the thing just won’t go https://cimg1.ibsrv.net/gimg/mitsubi...48c3079d3.jpeg I actually broke off the paint can key that I used, but the damn thing is still in |
Hi:
Perhaps this might work? Also some penetrating oil? Good luck, Ron |
Thank you sir!!
Originally Posted by jrmdir
(Post 336903)
hi:
Perhaps this might work? Also some penetrating oil? https://www.youtube.com/watch?v=c8huaunty9e good luck, ron |
Try to drive in several long screws into the seal. They should be long enough for the screw heads to stick past the cylinder head. Then use a short pry bar on those screws to dislodge the seal. Be careful not to sctatch the cam seal surface
| All times are GMT -5. The time now is 01:40 AM. |
