The horn wouldn't stop on 2003 Montero Limited & How I fixed it
11 Attachment(s)
Hello, I'm new to this forum, and originally came in search of an answer of how to fix a constant horn honk that appears in the middle of the night and particularly in cold weather. It is not the alarm, nor a bad relay or fuse, much to my dismay, I learned that the horn pad within the steering assembly was the culprit, shorting on typically during sudden depression/cold changes as a result of pressure from the airbag on thin wearing contacts within the pad and the repair costs for replacing the entire air bag assembly was upwards of $1200 depending on where you were quoted.
This killed my battery the first time it happened and tortured my neighbors while I slept. I brought the vehicle into my garage and couldn't replicate it, but the moment I left it outside a cold snap had me running out to bring it back in, to stop the horn, a simple tap/punch to the steering wheel seemed to get it to stop briefly but until you disconnect the short this will continue unpredictably. I brought it into the dealer on a warmer night and they couldn't replicate the issue but gladly would sell me a new assembly for about $1300 installed. Unacceptable on a car nearly 8 years old with constantly failing components, I've had to replace O2 sensors nearly every other year, and wasn't about to start doing the same with airbags that have a $1 switch broken in them. I with the assistance of my husband attempted to diagnose and repair the assembly based on a random thread I found for some montero/pajero users outside the US that were able to repair the contacts. Much to my dismay in attempting the repair it simply isn't possible and research with airbag repair folks in the US state it is NOT a serviceable part. No reputable repair guy will even try it. There are solid grommets holding the airbag in and I stopped after removing the ignition plate on the assembly that we really couldn't go much further forward. Unwilling to pay a lot for a fix, I did find a text writeup of how a guy disconnected the horn wire to the wheel and routed a new switch elsewhere on a 2001 Montero Limited. I did this as well, and have provided more detail and photos that I hope will help others. I believe the wire harness is the same on the 2001-2006 when speaking of USDM Monteros (not sport). Its a bit of a workaround but at least I have the horn back, I'm no longer worried about passing safety inspection in Virginia, and I didn't have to put an airbag on my Christmas wish list. I love my Montero in the snow and beach, but the random failing electrical stuff on the aging SUV is just annoying. This fix cost me about $10 total Parts included:
Tools required:
Here are the overall steps
Here are my Supporting Pictures: Locating bad horn switch wire: Attachment 6657 Locating Factory Harness Horn Wire: Attachment 6658 Locating Panel for new horn button: Attachment 6659 Where I grounded the switch: Attachment 6660 How to drill the panel: Attachment 6661 Drilled switch housing: Attachment 6662 Momentary Switch Used: Attachment 6663 Completed Horn switch panel: Attachment 6664 New Line tap to horn wire: Attachment 6665 Crimp Connections: Attachment 6666 Completed install: Attachment 6667 |
very nice, wish the mods would sticky or create a new sub forum for write ups, because support and aftermarket is few with our 3rd gens.
There are other nice write ups that just get lost as they get hold. This is a great contribution for the 3rd gen Montero/Pajero community. btw, i believe you mean 2001-2006 when speaking of USDM Monteros (not sport), your guide should apply to those years. |
you're right
Yes there is really very little information out there on our Montero's and its very frustrating. Thanks for the tip on what applies to I've corrected the post.
so you just press your new push button to sound the horn, its a very nice placement. very clean install.
All the reviews/and writeups I put up, I also post over on the 3rd gen pajero forum in AU http://www2.pajeroclub.com.au/forum/...isplay.php?f=8 MUCH more active, probably the MOST active 3rd gen forum. |
Nice Karen; so, tell me folks... is it just a matter of time and my '01 Monty is going to wake me up in the middle of the night? I'm at 156k, it's all good (i have the temp gauge w/ a mind of it's own). Should I do this fix and have done w/ it?
Originally Posted by Rougesvp
(Post 266407)
It's crazy, we really don't drive ours much, its got less than 60K on it, but it is not garaged. That might be the difference here with yours. Yep, I too have that freaky temp gauge thing too :( Comes back on for a few days after i reconnect the batt, then disappears again.. |
Originally Posted by redturboeclipse
(Post 266400)
All the reviews/and writeups I put up, I also post over on the 3rd gen pajero forum in AU http://www2.pajeroclub.com.au/forum/...isplay.php?f=8 MUCH more active, probably the MOST active 3rd gen forum. Yep, its a very economical workaround for those that would rather not spend the $1K+ on the airbag. |
My 02 just hit 60k. Also not garaged.
We may feel secluded and tendency to feel there are A LOT of problems with our vehicles.. but a way to see it is, look at the OTHER MANY Monteros out there. Today when there are problems people go on forums to complain or what not. The lack of members and complaining on forums leads me to believe our vehicles are reliable AHhaah, such an optimistic view |
01 Montero Ltd horn problem
Originally Posted by KarenV6
(Post 266408)
I honestly wouldn't.. if it isn't broken really no need, but I would at least take note of how it occurs (cold snaps/sudden barometric changes) and what to do to fix it immediately.. (push around on the horn pad on the wheel) and disable it by removing that horn wire under the wheel too. So much online how guys tried ripping out fuses, pulling batt cables, thought it was an alarm issue and it's really a simple problem.
It's crazy, we really don't drive ours much, its got less than 60K on it, but it is not garaged. That might be the difference here with yours. Yep, I too have that freaky temp gauge thing too :( Comes back on for a few days after i reconnect the batt, then disappears again.. Thank you. I am not that handy but should be able to find a helper to do it. |
Originally Posted by SoMaine
(Post 266476)
Karen - thanks for this great fix. I recently moved back to Maine fr AZ. One night back in October this problem first occurred. Nothing would stop it so I disconnected the battery cable. I don't drive the vehicle often - only 55K mi. I just reconnected the cables today and four hours later, 4:30 PM (28 degrees - not garaged) the horn went of again. I just disconnected the baterry cable one more time, but want to get it fixed right. Could you email the pics to me directly with your instruction set.
Thank you. I am not that handy but should be able to find a helper to do it. click thread tools you can email it to you or show a printable version.:p |
