How to adjust hydraulic belt tensioner?
I replaced my water pump and had to remove the timing belt. I've now got all the timing notches in the correct position and the belt reinstalled, but I'm having a problem with setting the timing belt tension.
I compressed the pin on the hydraulic belt tensioner. However I removed the tensioner wheel and found that the bolt is not in the exact center. I am now having trouble getting the wheel in the correct position before I release the pin in the belt tensioner. Does someone know of the correct procedure for putting the timing belt on? I'm also having trouble finding a repair manual for my 97 Montero Sport. Anyone know where I can get one? Thanks In Advance, Johnny |
RE: How to adjust hydraulic belt tensioner?
The timing belt adjuster is preset and you can not adjust it.You have to replace the timing belt adjuster and your problem should be solved.
Hey, that is not right. You need to compress the hydraulic tensioner. Then tighten the belt with that offcenter bolt thingy. Then release the hydraulic tensioner.
