Mitsubishi Pajero/Montero V78 MK3 3.2did - traction control light issue -
Old Oct 12, 2024 | 11:19 AM
andreikovacs's Avatar
Default Mitsubishi Pajero/Montero V78 MK3 3.2did - traction control light issue -
Hello group,
I am certain that somebody had gone trough the issues I will describe and will appreciate a lot a feedback because I am at the edge of selling the vehicle, I have gone through a lot with this car, including engine swap.
I am getting the traction control ASTC light on my dash. This happens when the engine get's around 90degrees (normal) and these go off only when I rev the engine around 2100rpm. Then after 10 seconds these appear again.
Also I think this is related, when the engine is hot, I can not switch back from 4x4 to 4X2, the other switches work.
I have checked for vacuum leaks, changed the MAP sensor, cleaned the intake manifold, change the traction control valve on the diesel injection pump.
Thank you!
LandauMech
Sep 14, 2023 12:39 PM
ChimiTA
Nov 5, 2009 10:14 PM
