Mitsubishi Pajero/Montero V78 MK3 3.2did - traction control light issue -
Hello group,
I am certain that somebody had gone trough the issues I will describe and will appreciate a lot a feedback because I am at the edge of selling the vehicle, I have gone through a lot with this car, including engine swap. I am getting the traction control ASTC light on my dash. This happens when the engine get's around 90degrees (normal) and these go off only when I rev the engine around 2100rpm. Then after 10 seconds these appear again. Also I think this is related, when the engine is hot, I can not switch back from 4x4 to 4X2, the other switches work. I have checked for vacuum leaks, changed the MAP sensor, cleaned the intake manifold, change the traction control valve on the diesel injection pump. Thank you! |
| All times are GMT -5. The time now is 02:05 AM. |
